Import of SolidWorks file .sldprt to COMSOL 4.0a
Topics: no topics
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   6 Replies   Last post: November 16, 2010 2:49pm UTC
Daniel Schwartzberg
Daniel Schwartzberg
September 18, 2010 8:41pm UTC
I have recieved some Solidworks files(.sldprt.) that I want to work with in COMSOL 4.0a. I have some problems opening them, though. After I have given the path of the file and press import I get the message:
"Internal error translating CAD model. File version is not supported"
As far as I know, I have the CAD import module which is supposed to support the .sldprt files.
What could the problem be?
/Daniel
Ivar Kjelberg
Ivar Kjelberg
September 19, 2010 8:57am UTC in response to Daniel Schwartzberg
Re: Import of SolidWorks file .sldprt to COMSOL 4.0a
Hello
it could be due to solidworks versions too, SW changes their format for each release (this makes life difficult even for us having the full CAD verson as SW is not downwards compatible, only "upwards"). I usually use the Parasolid .x_t format as this one evolves less and there are less version compatibility issues. From SolidWorks you can easily generate Parasolid files with a save as, aqt part or assembly level.
Note this is only for 3D files, 2D is limited and prt files are full 3D.
You need the CAD or livelink module to import these files. The main intereest with live-link is to run SolidWorks AND COMSOL together and have COMSOL update the geometry to search for shape optimisations. If you do not do such links (or do not have a powerfull enough PC to have both open simultaneously, then using simple file transfer works very well (witout the linked shape optimisation though)
Daniel Schwartzberg
Daniel Schwartzberg
September 19, 2010 6:46pm UTC in response to Ivar Kjelberg
Ivar, thank you very much for your reply!
I will ask for the file in Parasolid, .x_t, format instead. Hope it will work out.
/Daniel
Sam Rowles
Sam Rowles
November 16, 2010 2:34pm UTC in response to Daniel Schwartzberg
Did you have success with the parasolid export into comsol?
Daniel Schwartzberg
Daniel Schwartzberg
November 16, 2010 2:37pm UTC in response to Sam Rowles
Yes, it worked fine!
Sam Rowles
Sam Rowles
November 16, 2010 2:45pm UTC in response to Daniel Schwartzberg
Thanks for the quick reply. I am running solidworks 2010 and comsol 3.5 .....Any known problems with this?..Thanks, Sam
Sam Rowles
Sam Rowles
November 16, 2010 2:49pm UTC in response to Sam Rowles
One more question. Was you importing a solidworks assembly as a parasolid with multiple parts? Thanks, Sam
Rules and guidelines
